Is it possible to extrude a Cylinder arround a line with a given diameter without using a sketch?
RubensPurple
RubensPurple Member Posts: 2 ✭
Dear folks,
 i m first draw a line with two points and the function opFitSpline, than i want to extrude a Cylinder with a diameter, which i give in the annotation, around the created line.
thanks
  • mahir
    I don't believe that is possible. You're essentially trying to thicken a line, but thicken requires a surface input, not a curve. You will need to extrude a sketched circle or some other circular geometry.
    NeilCooke Moderator, Onshape Employees Posts: 6,114 image
  • mahir
    Well, I stand (or sit) corrected
  • Jake_Rosenfeld
    edited April 2020
    Technically fCylinder does use a sketch, you just don't have to make it yourself.  So you can be right too @mahir :)
  • mahir
    @Jake_Rosenfeld, shhh don't tell my wife :wink:
  • jrs_spedley
    jrs_spedley Member Posts: 71 ✭✭
    edited April 2020
    This reminds me of how many times I've wanted to use a point in a sketch as the axis for a rotation but I have to create a perpendicular plane, then a sketch, then a perpendicular line ...
  • john_mcclary
    john_mcclary Member, Developers Posts: 4,107 PRO
    @jrs_spedley you can just add a mate connector to the point. Then rotate on its z axis
