DRAWN BY is not updating when copying a drawing
brucebartlett
Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
in Drawings
I have been copying some drawings today done by someone else. This process works great but they still have the old DRAWN BY name and DATE DRAWN on the title block. I would have thought it should update when copied to the person doing the copying and the date copied.
john_mcclary
Member, Developers Posts: 4,059 PRO
Sometimes it takes a significant change for those properties to update. I'm not sure if the change needs to be made in the referenced part or the drawing. I find it a little annoying when this property isn't instant also.
Especially when you have an Onshape support agent's name appearing there because he helped you fix a problem in your doc.
I know you can manually override them in the properties, but i don't know if that breaks the automatic date5
Twitter: @onshapetricks & @babart1977
