Is it possible to change the drill points on a hole to a flat bottom hole instead of pointed?
greg_brcka
Member Posts: 3 EDU
I want to have a tapped hole but it be flat bottomed. I don't see that option.
8
PeteYodis
Moderator, Onshape Employees Posts: 578
@greg_brcka Our hole feature does not have that option yet, but it's something we intend to support. Is this a milled hole for a particular part it will pair with?9
you probably sleep
+ This also needs a variable, such as a 135 deg drill point for hard material and 60 degree for plastics.
+ Adding a 90 degree lead in chamfer is an abolute must for form taps. OTW: the threads bulge out proud of the top surface. I currently do this in cam as that is when I remember.
+ Threads should always default to course, or to company's preference.
