If you would like to contact our Community Manager personally, feel free to  send a private message or an email.
Help creating threads
otaolafr
                    Member Posts: 113 EDU
                    hello, I am trying to create BSPP threads, to be exactly G1/2 and G1/4
my issue is that if i create with the exact dimensions i get an error when i do the sweep, I know that I is because it shares one point in each turn of the helix, but I do not understand how can I do it respecting the thread dimensions here is what i am trying to do:
https://cad.onshape.com/documents/d9d8882d84c270ac9346a52f/w/f1e0d79458dde1b376cc553c/e/a32892f6c9a0702d59076c9f
and here are the dimensions I found for the BSPP threads:
https://amesweb.info/Screws/bspp-thread-chart-calculator.aspx
EDIT: i solved by giving the number of turns in the helix and not the pinch of the thread. hope helps someone
best regards, franco
Mr_GK
                            Member Posts: 19 ✭✭
                    I am not able to access your model.
as I saw, you solved by yourself, didn’t you?1
I'm trying to do a symbolic BSPP thread on a hole, however I don't know how to make it.
Does the software has an option on the hole command for tapped holes? I seem to see only ISO, ANSI, DIN and PEM?
Thanks
