Change distance between sketches
yuggniiksyuggniiks Member Posts: 25 EDU
edited June 2020 in Drawings
When setting up this drawing, I offset my plane and then made my second sketch.
I've now decided I want to play with dimensions between the two sketch planes, but uncertain on best way to do this with my existing sketches.
I tried adding a construction line, and dimension it between the two sketches & planes of interest.
I then changed the dimension to "change to driven dimension" but this turns it red (over constrained).
    The offset is defined in your Plane feature.
  • yuggniiksyuggniiks Member Posts: 25 EDU
    edited June 2020
    Oh wow, it's so obvious to me now :)
    Thanks again @NeilCooke
