how to draw part of assembly?
malet_jl
Member Posts: 15 ✭
hello,
I have an assembly, that is configured using configuration variables, this assembly has sub assemblies, which are in turn configured with configuration variables, and parts that are in turn configured....
I now want to create a drawing for production, but I need to draw using the assembly configuration.... I didn't found a way to import a part configured from the assembly, I can import parts but the dimensions aren't good...
I can create exploded views, which is great, and in a way answer my needs, but on the exploded view, I can't hide some parts.... which makes impossible to only show what is required...
how can I do that?
thanks and regards
how can I do that?
thanks and regards
Display States, in the assembly, will hide other parts - or you could just find which configuration of the part is used in the assembly and create a drawing of that.Senior Director, Technical Services, EMEA5
and how can I orient a part assembly to fit the axes? I can fix a part, but in drawing it will never be usable since top/bottom/left/right views are based on axes, and assemblies are "free to flight"?0
You can mate parts to the origin or model them in the part studio in the orientation you want and "fix" one/group the others with the fixed one in the assembly.Get in touch: contact@alnis.dev | My personal site: https://alnis.dev
@alnis is my personal account. @alnis_ptc is my official PTC account.0 -
not sure about what you means.... should I fix it in during part design? the issue I have is that when I imported the parts I didn't fixed the reference one, so onshape moved all part during relationship, and now I don't know how to reorient the one I want to fix.. and I don't want to redoo all the job
oh, I understand.... I can create a mate connector with the origin, so better than fixing a part using rightClick->fix I created a fastened mate connector between one auto-mate and the auto-mate of the origin, now I can apply rotations to have it oriented as wanted....0
