Parametric vs Configuration Variables article
alan_baljeu
alan_baljeu Member, User Group Leader Posts: 111 ✭✭
https://learn.onshape.com/learn/article/parametric-variables-vs-configuration-variables
This article has a few points where the statements really could use demonstration or clearer example.  I managed to puzzle through a bunch, but this one has me stuck:
  • Parametric variables allow a multitude of inputs because they are considered features. You can define the value of a Parametric variable off of a user inputted value, dimension, formula, another variable, or any combination of them.
I don't know how to use anything other than a formula.  How do I reference a dimension in a variable?
Creating knowledge-driven design automation software, for molds, etc.
www.virtualmold.com
  • john_mcclary
    john_mcclary Member, Developers Posts: 4,107 PRO
    Only way I know how to set a dimension to a parametric variable is to create the variable in featurescript.
    here is the most common example: https://cad.onshape.com/documents/77baa8153589a7fc5f289829/v/ceb4a03e4ac77173bf6d0074/e/181cb871f3008e6b885df46a
  • romeograham
    romeograham Member, csevp Posts: 777 PRO
    The other way to "use" a dimension as a Parametric Variable is to use the excellent Measure Value featurescript.
    You can use it to measure the dimension you want to use later, and create a variable that you can use directly, or however you want later.
    Here we have a dimension (5cm) that we want to use later as a variable:
    Then we use the Measure Value FS to create a Variable (I called it #length) to use later:
    Now, #length is available to use any way you'd like. We can use it to set the length of a blind extrude:
    Or as a variable in an expression:
    ...which updates nicely when I change the dimension in the first sketch:
    You can use the Measure Value FS to measure quite a few different things.
    One of the interesting things about Parametric Variables, too, is that you can set a new value further down the Feature List. Onshape will solve for #length using what ever value is valid at that point in the Feature List:
    You can even use a Variable inside itself. This is useful for accelerating or variable pattern work (search for @NeilCooke 's "pretty patterns" posts / documents and this webinar for great learning materials).
    Good luck!
    Romeo
