Improvements to Onshape - October 27th, 2020
2»
  • john_mcclary
    Agreed, I NEVER want view simplification on.
    If I don't want something shown I make display states or configurations. Many times I have small parts that are the size of washers that need to been shown.
    Please make this option configurable on the user or company level or something.
  • alnis
    alnis Member, Developers Posts: 453 EDU
    I agree with @LKRENZLER - I definitely miss Inventor's impressive responsiveness with big models, especially in drawings. Onshape is still faster (and a lot more stable!) when it comes to getting work done overall, but there are some little things like that which make it a bit less enjoyable to use at times.
  • LKRENZLER
    LKRENZLER Member Posts: 30 ✭✭
    One thing I have noticed is that when waiting for drawings to update, there is no local CPU or GPU activity which seems to indicate that all the processing is done on the cloud somewhere.  This really needs to be local.  We have Solidworks and Inventor to test here and drawings that take 20-30 seconds to update on Onshape are almost instantaneous on the other two mentioned.  It can be done and should be.  Onshape is almost unusable on large assemblies.
  • MBartlett21
    edited December 2020
    I don't think adding named attributes without types was a good idea, as there can be collisions between unrelated features.
    For example, if my feature sets an attribute called "someAttribute" with a length value, then another feature also sets an attribute called "someAttribute", but with an angle, that would then break my feature that expects the attribute to have a length value.
    Apart from that, the OBJ export seems useful, and the 'where used' as well.
    IR for AS/NZS 1100
    S1mon Member Posts: 4,613 PRO
    The setup walkthrough is nice. It would be even better if Enterprise customers could set the defaults for the units and view controls for new users.
  • MBartlett21
    3 weeks...
    IR for AS/NZS 1100
  • emagdalenaC2i
    Funny Animated Alarm Clock Gifs
    Un saludo,
  • john_mcclary
    omfg... someone needs to slow down the clock... months have been passing like weeks lately...
    Can't wait till these projects are done  :s
