DWG import
3dcad3dcad Member, OS Professional, Mentor Posts: 2,477 PRO
edited August 2015 in Drawings
Dwgs seems to currently import as non-editable image which is .. well .. 99.9% useless.
We need full dwg/dxf support with:
- full editing support (without the need to explode or other activation)
- dimensioning (like it was created in Onshape)
- snap to all common spots (like it was created in Onshape)
- scale line thickness on zoom (vector graphic)
- easily add group or fix -constraints to complete drawing (so that any additional lines or dimensions doesn't brake the original)
- possibility to import dwg/dxf into new sheet to current drawing
- select part of imported drawing and copy to new sheet
- create a block from dwg/dxf (or Ons drawing) which can be quickly inserted to another sheet or drawing (like common detail or logo etc.)
//rami
