In Part/assembly properties allow part number to be a formula
ryan_mcgoldrickryan_mcgoldrick Member Posts: 71 ✭✭✭
edited December 2020 in Data management
Example,
Our part numbers are made from
Project number- Item Number - Version Number - Release Number
In solidworks we could use a formula to automatically generate the Part number
something like #/= Project number - Version Number - Release Number
- = Dash not a minus.
0 votes
Declined · Last Updated
Due to the current close tie to Release management, we will be opting to integrate to another system to provide this sort of number generator.
    We will not be considering this at this time due to the close tie to Release management but are looking at integration into other systems that do this number scheme.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,051 PRO
    you can do this today very easily with featurescript.
    I've done something like this before so it renumbered my entire project.
    Basically for the fields here you jut make variables
    Here is some base code to get you started:
    FeatureScript 1403;
    import(path : "onshape/std/geometry.fs", version : "1403.0");
    annotation { "Feature Type Name" : "Part Propertiesx", "Feature Name Template" : "#Name" }
    export const PartProperties = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            annotation { "Name" : "Part", "Filter" : EntityType.BODY && BodyType.SOLID && AllowFlattenedGeometry.YES, "MaxNumberOfPicks" : 1 }
            definition.entities is Query;
            annotation { "Name" : "Name" }
            isAnything(definition.name);
            annotation { "Name" : "Name Includes Part Number", "Default" : true }
            definition.NameWithPartNumber is boolean;
            annotation { "Name" : "Job Number" }
            isInteger(definition.JobNumber, POSITIVE_COUNT_BOUNDS);
            annotation { "Name" : "Unit Number" }
            isInteger(definition.UnitNumber, POSITIVE_COUNT_BOUNDS);
            annotation { "Name" : "Detail Number" }
            isInteger(definition.DetailNumber, POSITIVE_COUNT_BOUNDS);
            annotation { "Name" : "Is Sub Detail", "Default" : false }
            definition.isSubDetail is boolean;
            if (definition.isSubDetail)
                annotation { "Name" : "Sub Detail Number" }
                isInteger(definition.SubDetailNumber, POSITIVE_COUNT_BOUNDS);
            const part = evaluateQuery(context, definition.entities);
            const JobNumber = toString(definition.JobNumber);
            /* add leading zeros Detail number */
            var x = definition.DetailNumber;
            if (x < 10)
                x = "00" ~ toString(x);
            else if (x < 100)
                x = "0" ~ toString(x);
            else
                x = "" ~ toString(x);
            const DetailNumber = x;
            /* add leading zeros Unit Number */
            x = definition.UnitNumber;
            if (x < 10) /* add leading zeros */
            else if (x < 100)
            else
            const UnitNumber = x;
            /* Format Part Number */
            var PartNumber = definition.JobNumber ~ "-" ~ UnitNumber ~ "-" ~ DetailNumber;
            /* Add .number for sub details */
            PartNumber ~= definition.isSubDetail ? "." ~ definition.SubDetailNumber : "";
            /* Rename part to include part number if wanted */
            const Name = definition.NameWithPartNumber ? PartNumber ~ " - " ~ definition.name : definition.name;
            /* Make Feature on tree match part name */
            setFeatureComputedParameter(context, id, {
                        "name" : "Name",
                        "value" : Name
            /* Save properties to part */
            if (part == [])
                throw regenError(ErrorStringEnum.CANNOT_RESOLVE_ENTITIES, ["entities"]);
            const Part = part[0];
            setProperty(context, {
                        "entities" : Part,
                        "propertyType" : PropertyType.PART_NUMBER,
                        "value" : PartNumber
                        "entities" : Part,
                        "propertyType" : PropertyType.NAME,
                        "value" : Name
                        "entities" : Part,
                        "propertyType" : PropertyType.DESCRIPTION,
                        "value" : definition.name
