Global configuration in the document. My workaround. How to make it works?
vijit_codervijit_coder Member Posts: 11
edited December 2020 in FeatureScript
I spent a few hours of digging in the forums and manuals. I know that Onshape still hasn't a normal way to make global configuration at least in the bounds of the document. Ok.
I tried to invent the crutch. And I almost made it, I think. But it doesn't work :(
Here is the demo document - https://cad.onshape.com/documents/057ed93cbbf4ea11c405e9ed/w/4b232b5d232857ea4f611124/e/06d16d4e725713c329d7b24a.
Tab "configuration" - it should be a global config of the document. No sketches there, only configurations.
Tab "fs.globals" is a crutch itself. It serves as a bridge between Configuration and other PartStudios. Mapping of configuration to variables.
Tab "demo" - demo part studio.
At the first glance it works. I specified some values in the config and used their mapped variables in the demo sketch. As you can see the rectangle in size of the config values.
But when I changing the configuration it doesn't apples anymore to my sketch. Even if I'll draw a new objects, they still "see" the old config values mapped to the variables.
So, how to update FS variables when configuration changed?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 6,039 image
    That's not going to work because config variables are treated differently than feature variables. When you call the build() function, it is not reading the user-set config variables (because a Part Studio can have infinite variations). I'm sure there's a better explanation, but that's the long and short of it. Take a look at "instantiator" which might give you more background or ideas.
  • vijit_codervijit_coder Member Posts: 11
    Got it. Thanks.
  • Alex_KempenAlex_Kempen Member Posts: 258 EDU
    I have a FeatureScript for this currently in the works, which uses setAttributes to read off attributes previously set with FS in another part studio. I plan on releasing it sometime in the next week or so. You can find more info about it in this forum thread.
    I saw that thread already.
    My intention is to share configuration, not the variables in the PartStudio. It's a big difference from the user point of view.
Howdy, Stranger!
