accessing one coordinate of a vector?
EvanReese
Member, Mentor Posts: 3,059 PRO
I'm trying to use a triad manipulator to set 3 different length parameters (XY and Z coordinates). Since the base and offset of the triad are both simple vectors I'm not sure how to send the x value to the X length parameter. Is there a way to get one of the values out of a vector? Am I asking the right question? Manipulators in general are new to me too, so any info helps.
@Evan_Reese
3d vectors in Onshape are just a simple array of three ValueWithUnits, meaning that you can get the x, y and z dimensions with vec[0], vec[1], and vec[2], respectively.0 -
You can access the vector as an array to get the x, y, and z components. Like myVector[0] to get the x component.The Transform feature uses a triad manipulator, you can take a look at the transformManipulatorChange method in transformCopy.fs in the standard library. I've copied the relevant portion here:const offset = input[TRANSLATION].offset;You can also use the dot product, like dot(myVector, (vector(1, 0, 0))), which would get the x component of myVector.
output.dx = offset[0];
output.dy = offset[1];
output.dz = offset[2];
2
@Evan_Reese
2 -
I'm really glad it's that simple. I thought that's what I'd tried but I must have not had it quite right. I've got it working now.
