Back in the shed again
billy2
Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,117 PRO
I'm beginning work on my Harley because I don't like her rear fender
Trying to come up with a design using detailing tape became frustrating and time consuming. I wasn't getting there
So I decided to throw it into CAD and try designing the shape virtually. It was actually faster & easier to conceptualize virtually. This seems odd that CAD would be faster to layout a design than throwing down some detailing tape, but it's true. I had better success in CAD
Since I was inside CAD, why not design a new tail lamp
This ain't just no common 12v bulb. It's a 12 watt high powered LED and I'll have to turn it down; I think it'll be too bright. The lens uses an elliptical pattern which will spread the light out horizontally making it easier to see from the sides. It should probably be IP67 so if it starts raining the lamp doesn't short out. And, with any high powered lamp these days, you have to have a good thermal strategy so the lamp doesn't melt and drip off the end of the fender. Easily done if you're an ME, basic thermal stuff.
I keep all my design notes in my shed
https://rustyshed.com/?quill=5ede3f5abd6fba042805cf13
3
Showing 3 lamps, I'm only going to use the top lamp on my bike, the sides are just for show
Side lamp at a 20°
Top lamp is straight
