Export geometry only in a dxf format from drawings
bryan_lagrange
Member, User Group Leader Posts: 984 ✭✭✭✭✭
I create most of my dxf files from 1:1 scaled drawings in Onshape (old habit hard to break). Issue
I am having is when I .dxf a flat pattern. Even though I hide the bend
notes and only the geometry appears on the screen when exporting the
.dxf file the bend note is still attached in which the note needs to be
removed in CAM and or opened in another CAD software, removed, and save
again as a .dxf. Would like the ability to have another option in the
download menu to dxf geometry only.
Current result:
Proposed solution:
Current result:
Proposed solution:
Here is the flat pattern with notes and bend line
I hide the bend notes and bend lines before exporting then export to .dxf format
This is what I get in the CAM software when opening the .dxf
Twitter: @BryanLAGdesign
