Filling in holes
wayne_sauder
Member, csevp Posts: 647 PRO
in General
I fill a lot of holes on imported parts. the only tool I have found the does that is the move face. The example I included is real simple but on large parts with lots of holes that are all different sizes that can be a bit tedious, is there a better workflow? I recreate holes as I did in the example document to take advantage of the hole features in the drawings.
https://cad.onshape.com/documents/631c5803ef2b2277fad7a404/w/f947c58906c01b7e8ae98fde/e/bbf0d07f6cabd08d84bf3e18
How about Delete Face
When I think the number of holes may change (in this case updating the imported file)
then I like to use a sketch on the face and just blank it out using an extrude up to face.
(This would be if you had a bunch of stuff on the face you want to change to native features after tracing them with a sketch)
If the part is square (like in this case)
then you can skip the sketch and just extrude one of the side faces.
But, If you just want to delete the faces or want more precision (not all holes or features on the face), then that's where delete face is very helpful.
Also, I see you were using the "create selection" tool. That is good for when you need more precision in your selection.
In this case you shouldn't forget about the traditional window-select as Steve and I used in these examples.
Figured I would throw a few options your way so you could make a judgement call for your needs
