mate overdefines the assembly
john_minnee507
john_minnee507 Member Posts: 5 ✭✭
I can't seem to get these mates to work and I can't figure out why. I was doing great when things started to going bad. (Assembly 1 was working brilliantly then went bad. Assembly 2 was going well, with both pistons working fine, then I started to go backward. Now I can't get the revolve connection to work and I don't know why. What am I doing wrong?
    NeilCooke Moderator, Onshape Employees Posts: 6,103 image
    Having too many revolutes can cause the system to bind up due to tolerance issues - cylindrical adds a translational DOF that eases that. You wouldn't have guessed without me telling you.
  • CBowers
    CBowers Member Posts: 50 PRO
    Try changing Fastened 3 and 4 to Revolute mates
  • john_minnee507
    Thanks, I tried that, but it still does not help. Theoretically if the mate between the piston and conrod are revolute these would not need to be revolute mates.
    Delete Revolute 9, change Revolute 1 and Revolute 2 to Cylindrical.
  • john_minnee507
    thanks Neil, that worked. I haven't used that mate before, so I will have to work out the differences
