Moving Edges?
PvSaurrmaPvSaurrma Member Posts: 9
edited April 2021 in Using Onshape
Is there a way to move a single edge?
I'm trying to build a model on which one surface is tilted in two different directions. Using the "move surface" command and rotating it only allows me to tilt the surface on one angle.
Below an example made in Sketchup to show the general form, I'm trying to archive
    #2
  • PvSaurrmaPvSaurrma Member Posts: 9
    Thank you @mahir! That was exactly what I was looking for, just slightly embarrassed that I didn't come up
