How to use 'configure' part and face colors?
mr_deekmr_deek Member Posts: 6 ✭✭
Hello,
I'm looking to "configure" different parts with colours depending on the "configuration".
I don't see this as a build in option.
I tried looking at existing featurescript, but it seems there are limitations* .
* Limitations - The part or surface can not have been prior assigned an appearance or it over-rides the feature script values.
Testing (parts 1 and 2 and face 3 have been manually set and now the scripts can not affect the colours. You can also see part 3 and 4 where no manual colour has been set the featurescript work as expected.:
https://cad.onshape.com/documents/71991c8436dd659da28d0a70/w/15b7f27028eaf9982f6009a2/e/e667e30bc48e274e7b459718
What can be done to have have one part with selectable colours?
Thank you in advance.
Mr.Deek
  • mr_deekmr_deek Member Posts: 6 ✭✭
    Ok, I'm thinking found a poor work arround ...
    Click on the part ... go to "properties"
    Click on "Reset All" properties.
    Is there a way to only remove the "Colour" properties without resetting all of the part configuration?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,866
    You can configure colours through the UI
  • ben_partouchben_partouch Member, csevp Posts: 158 PRO
    @NeilCooke is this not possible in assemblies?
    I can't add Appearance property...
    Thanks.
