Very simple pattern takes forever
rune_thorsen229rune_thorsen229 Member Posts: 182 EDU
Hi, Years ago I ran into the problem of patterning a sketch and it took forever. The advice was to pattern a part
Now I try to make a 20x20 pattern and the performance is really slow. Is that normal?
https://cad.onshape.com/documents/77132658b0c906c0b466bc80/w/4c5f7891b0e3bb4b1df4bda5/e/66c031ac896c70b237872a08
The regeneration time is about
3 minutes. It it a local machine problem or on the server side?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,926 image
    I am seeing 25s here:
    Regeneration is all server side, so check the values again.
    Anyway for things like this, it is the boolean operation that takes the time. Please review my blog post to see some techniques for speeding things up: https://www.onshape.com/en/resource-center/tech-tips/tech-tip-how-to-create-faster-patterns-in-onshape
    I'm sure I could make it faster
    OK I was looking at the wrong Part Studio, but even so, the techniques are the same
  • rune_thorsen229rune_thorsen229 Member Posts: 182 EDU
    Thanks @NeilCooke, so my 188 seconds of regeneration time was maybe because the server had a busy day? Today it gives 41 seconds if I change the tilecount from 20 to 22. Mind you if you don't change the parameters it obviously regenerates much faster. Well I did check the blog but cant see how to speed it up.
    If I skip the boolean cutout it gives 39 seconds.
    If I try to make 100 tiles I think I should go for lunch ;-)
