EDIT IN-CONTEXT AND CREATE NEW BRANCH
shawn_crockershawn_crocker Member, OS Professional Posts: 957 PRO
edited August 2021 in Product Feedback
I frequently want to customize a part of sub assembly to tailor it to a customers requirements.  Naturally I want this special version to be in its own branch of the document.  90% of the time I need to edit the part in context.  When I right click and select "edit in context" I would love to have an extra option there that say something like "edit in context in new branch".  At the moment I select edit in context and when the document opens, I create a branch.  When the new branch is created, The context also gets removed.  I then navigate back to the assembly, update the part to the version of the newly created branch and edit in context a second time.  I would be kind of great to just be able to have the branch and context get created all in one go.
    @shawn_crocker There are a few things that we pause on when requests for workflow specific automation is asked for.  Branching when you do an in context edit is a bit dangerous only because this would happen in a document that is somewhat hidden from you.  Typically you are doing these things and you are actually "out of context" from the document you are branching.  This might sound like a simple option but if you have a very complex version graph, this could be damaging.  We like to make sure users are doing branching intentionally so at this point we will not add this to the list.
  • shawn_crockershawn_crocker Member, OS Professional Posts: 957 PRO
    I see and understand the concern for opening up an opportunity for people to unintentionally damage there tightly tuned document structure.  No biggy
