Mate Matching Surfaces
lorenz_poiger
Member Posts: 17 ✭✭
I would like to mate these two parts so that the surfaces are touching eachother (The parts will be welded). They both have the same radius and should fit together perfectly. Is there an easy way to do that? Or do I have to use the fastened mate? Tangential doesnt work, but I'm unsure if I understand how the function works.
BenTaylor Member Posts: 44 PROA fastened mate is probably the best way to go. You can mouse over the coped face to select mate connectors at the center of the curved surface (see screenshot). You may have to use an offset unless you want it exactly aligned with the midpoint of the larger part.
(link to my assembly)
1
Lead Mechanical Engineer @ Healing Innovations
Onshape Ambassador
However, this looks like a static sort of frame, so I bet the design will come together better if you model it as a single part studio and use a group to hold everything together. In particular, the Beams custom feature might be useful using custom circular profiles:
https://cad.onshape.com/documents/e15c2c668d138f01242d0c80/w/0664d65a957c7bfba7cfbddd/e/2d5660fc1012df9598f00251
Edit: whoops, sorry @BenTaylor! Looks like I posted at the same time as you
