Aligning parts to a common origin
lougallo
Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016
As we are working on bringing an origin, planes and Part Studio reference planes to Onshape Assemblies, there is a simple way to work around this now. I know a few of you have discovered this approach and I thought I would share.
This can be done with a simple block but for the purposes of presentation, I have done a bit more than that. In one PS I build 3 simple axis and moved them in place to share a common point. Once we have this we can follow the animation below:
Steps:
Now you will have the fixed entity in the Assembly to lock to. The shared vertex can act as an origin and the faces of the axes can act as planes to mate to. When you are done, hide the parts. Once we have these are part of the Assembly interface I will update this post. ~Lou
Steps:
- Insert entire Part Studio into an Assembly. ( don't click in the graphics area which keeps it on the hidden origin .)
- Select the 3 parts of the Part Studio and Group them to act as a single entity.
- Fix one of the parts
2
