Changing color preferences on tools?
jack_erhartjack_erhart Member Posts: 140 ✭✭
I'm finding these old eyes are having a hard time picking up some of the inference ques. The colors seem to get washed out with the white background. Is there a way to change those? Also, can we get a hot key for "Center point Arc?" Please?
  • Jake_DelanoJake_Delano Member, Onshape Employees Posts: 43 image
    There is currently no way to change colors in Onshape, and while there is not a hot key for center point arcs at this time, you can add the tool to your shortcut toolbar for easy access if you have not done that already
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,981 PRO
    There is a hack to change colors and stuff through CSS
    if you install the "Stylus" extension then you can configure colors that way
    Stylus :: add0n.com
  • jack_erhartjack_erhart Member Posts: 140 ✭✭
    Stylus :: add0n.com
    Thanks John. But I have to say I'm not interested in much of anything that starts with "Hack." I was hoping that Onshape would have an answer within thier program. But I appreciate the intent.
    I understand. There are many tickets out there for themes, and have been for many years. But in the mean time at least you have some options.
