[Feature Request] Ability to add favorite directories when adding new part in assembly
n_schoemaekern_schoemaeker Member Posts: 28 PRO
Hi,
in the menu "Insert parts and assemblies (i)" in an assembly, we have three main tabs: "Current document", "Other document", "Standard Content". When we select "Other documents", it lists "My OnShape", "Recently Opened",  "Created By Me", "Shared with Me" and "Public". It would be very useful if we could add our own shortcuts / favorite directories (or maybe even documents) there. I happen to have a few common directories from which I regularly add components, and navigating through them is painful. The "Recently Opened" feature helps a bit, bit is not enough IMO.
Thanks in advance !
    The insert dialog also shows labels which is good for individual docs or you could also create a team and share a folder to the team.
  • n_schoemaekern_schoemaeker Member Posts: 28 PRO
    Thanks @NeilCooke for the tag tip, I'll try to use that for now.
    Creating a Team and adding to folder seems like a hack, but tags are all right.
    I still hope this favorite feature gets added once, though!
