Mates for a L-shape path
johannes_beckerjohannes_becker Member Posts: 8 ✭✭
Is there a way to to restrict the movement of parts in an assembly such that one part can move only along a L shape path? It is for a part that drops in from above and then slides horizontally. It would be like a slider mate vertically and at the end of the allowed path a slider mate horizontally.
Any hint will be appreciated
Johannes
  • EvanReeseEvanReese Member, Mentor Posts: 2,865 PRO
    You can kind of cheat it using some dummy parts and surfaces and a tangent mate. Here's a super quick example. @john_mcclary
    is the master of this technique though, so he probably has better input. I mean, he animated solving a whole rubiks cube in Onshape which still blows my mind.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,052 PRO
    edited January 2022
    @Evan_Reese
    yea, that's pretty much how I would have done it
    Further Suggestion:
    If you have a lot of places where that path is needed, then you could make a configurable assembly that has the path and arrow, insert that assembly in every place you need to mate, and change its configuration to drive the path and shape. That way you can have a ready to go "L-Mate" that can be re-used while only drawing it once. At the same time the configurations set the 'limits". Then add a couple of mate connectors within it and it should be a rather decent work around. rather than matting a bunch of stuff in the main assembly on the fly.
  • matthew_stacymatthew_stacy Member Posts: 489 PRO
    I am many things, but fast ain't one of them.  @e@Evan_Reese and and @j@john_mcclary beat me to the punch, but for whatever it's worth here's another serving of the same basic flavor.  Onshape has a useful tech tip video demonstrating a related application of the tangent mate.
    Note, that one requirement to radius the corner of the "L".  Make that radius as small as you want, but R>0.  The only way that I could get the tangent mate to accept the entire face of the "L" was to construct a dummy PART.  Kudos to John for making that work with a SURFACE.  I'm still not sure how he did that.
    I chose to use a ball (sketch & part) and a "Ramp" part:
    • Ramp is fixed
    • ball sketch grouped with Ball part
    • ball sketch mated planar to origin (orientation of that origin mate connector can be persnickety)
    • vertex of ball sketch mated tangent to face of Ramp part (dummy)
    Hide, but don't suppress, the dummy.  Note that you can mate the surface of the ball part tangent to the ramp (B1 branch, V2), but the geometry calculations must be more complex because the movement is not as stable when you drag the ball around the corner.  I suspect the singularity of a sketch vertex is the better choice (Main branch, V1)
  • johannes_beckerjohannes_becker Member Posts: 8 ✭✭
    Thanks folks. I will give that a try
