Alternatively, while inside your sketch, there is a sketch constraint called Fix which you could use to lock your sketch in place. Note that it is not best practice and your sketch will no longer be parametric.
So, you shouldn't have to worry about someone moving it by accident.
but if you are worried, select all the entities and add the "fixed" constraint
I wish Onshape would add this feature
