Is there a way to have all documents/projects etc automatically shared upon creation with teams?
ryan_mcgoldrick47ryan_mcgoldrick47 Member Posts: 93 ✭✭✭
Would be great for Electrical team colleagues to be able to see everything as reviewers without requiring someone to provide access by manually going and finding the project or document and sharing it. similar to how Altium does it, we as the mechanical team can see all the active projects, go into them, view, export etc easily.
  • EvanReeseEvanReese Member, Mentor Posts: 2,776 PRO
    I'm with Ryan here. We default to "open" and only add privacy where it makes sense. This would be a good global setting for that.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,957 image
    If the docs are in folders or projects, yes.
  • ryan_mcgoldrick47ryan_mcgoldrick47 Member Posts: 93 ✭✭✭
    But this requires you to either share it with a team upon creation as in the folder or project, or at a later date share it with a team. I would like by default all documents to be viewable with certain permissions to certain teams without input every time.
  • adrian_vlzkzadrian_vlzkz Member, pcbaevp Posts: 302 PRO
    That is what Projects are for, if you have you users organized by team permissions are only assigned once at the project level, anything that gets added to that project would be visible to the teams that have access to it.
    CAD Engineering Manager
    Would be better to not have to do that at project level and just have it all shared with the company with set permissions.
  • S1monS1mon Member Posts: 3,886 PRO
    Would this work: create a project template with default permissions to certain teams, and then whenever you need a new project, you can just duplicate the template?
    Yeah, definitely that makes sense for smaller teams. That's why I'm a big proponent that these things need to be "options" in the environment configuration. You don't want to force a smaller implementation to operate like an enterprise, and vice-versa; you don't want an open world in a controlled multi-team environment
