Is there a way to customize part names within an exported zip file?
skybrian
skybrian Member Posts: 25 ✭✭
When I export a zip file for a document with "export unique parts as individual files" checked, typically the filename is "${document.name}.zip" and the files within it are "${document.name} - ${part_name}.stl". I'm wondering if there's some way to get rid of the document name portion of the filenames within the zip file?
I tried making an export rule with "Part" scope in preferences, but it had no apparent effect on filenames within the zip file. I'm not sure if I understand how these scopes work.
(I also noticed what seems to be a bug: the timestamps for filenames within a zip file are seven hours in future, perhaps due to a timezone difference.)
