How do you undo an appearance change to revert to the default?
I normally control appearance using FeatureScript. If I manually play with the color of a part, then the FeatureScript code that sets the appearance is overridden. How can I revert to the default color scheme so that the FeatureScript appearance changes are applied again?
  • EvanReese
    EvanReese Member, Mentor Posts: 3,077 PRO
    If it's added to a face, not the part, then you need to open the appearances panel and delete the face appearances. Does that do what you need?
  • eric_pesty
    eric_pesty Member, pcbaevp Posts: 2,897 PRO
    I think what you are looking for is the "reset all" (or something like this) at the bottom of the properties. However it's all or nothing so it will reset all of the properties...
  • monroe_weber_shirk
    monroe_weber_shirk Member Posts: 103 EDU
    The reset button is grayed out even after I add an appearance to a face.
  • EvanReese
    Okay! That is sweet. Thank you!
  • joel_vermeulen296
    joel_vermeulen296 Member Posts: 3 ✭
    edited February 2024
    I still have problems to remove specific face appearances, as when I remove all the selected faces, the green accept tick mark turns gray and i cannot select 0 faces, to remove the change completely. clicking the red X just returns to the previous state.
    Also:
    Is there an appearance panel other then the one reachable through right click?
    NeilCooke Moderator, Onshape Employees Posts: 6,108 image
    @Joel_Vermeulen there’s an appearance panel on the right.
