New API explorer
billy2
Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,119 PRO
can't seem to login
seems pretty straight forward, I have both client & client secret. Have tried with & without "=" signs at end. Have tried both escaped, but I can't authorize.
My redirect is to my site, this seems odd since I'm using the apiExplorer, why would oAuth go back to my site?
www.virtualmold.com
I load API Explorer. Clicking through bring you to this screen. This is where I was confused (I thought I had to click Authorize button). Ignore this message for now. Unlike the old API Explorer being logged into OS gives you auth. It is that simple!
As a test scroll down to Thumbnail and plug in a did. For this I used a public file. This is the part of the url string you want to grab. You can do this for any file you have writes to.
This should give url links to all the current documents thumbnails. The links will work while you are logged in, but will not work in incognito.
From there is should be the same as the old API Exporer, only different.
www.virtualmold.com
-current
-oauth
-api key
Logging into onshape is all that is needed to use the new api explorer. I don't know why I made it complicated. Once you have the URL, you don't need the tab.
I do wish it'd remember DWE, I liked that about the old one.
@bill_schnoebelen, I finally figured it out....
