Follower with rotating and translating movement
sarah_martinez903sarah_martinez903 Member Posts: 7
I am working on an automata project so that I can show students how to animate their projects. I have most things figured out, but I cannot seem to get a follower to both rotate and translate up and down with the follower. I know I need to do a gear relation, but that only relates the revolute of the follower and the axle of the main rod. I am looking to get the follower to follow along with the path of the cam and rotate, but anytime I try to do both things, my assembly breaks.
Here is the link, hopefully it works.
https://cad.onshape.com/documents/a7c1c1ab9dc6774e1d2994f6/w/ddd5d521065e30612d8be670/e/23cc3e415c13e911f4ad2eb0Thanks
    edited April 2022
    @sarah_martinez903
    SEE BELOW
    edited April 2022
    @sarah_martinez903
    https://cad.onshape.com/documents/8ddad83224c365f84606959b/w/92ebd1cffee14ecc2d8410e1/e/c8939d27d61b6e73b5f7a44a
    OK this one is working where every part is moving the way it should
    in my previous post up above, that model was using a bit of trickery to get it to work. The vertical shaft was actually not rotating
    But in this model, you can see that I added a little extra part that is FASTENED to the vertical shaft and that’s an indicator showing that that shaft is also moving in a rotational motion
    I had to add an extra part to get it to do what it’s doing. The part is hidden
    You have to manually crank that horizontal shaft to get everything to move
    edited April 2022
    @sarah_martinez903
    This is a finicky set up here. The assembly can go batty
    but the GIF herein shows a fix
    You just have to rotate the vertical shaft a little bit to reset it
    As far as the tangent mate, I think it’s gonna just operate in the red. If it really falls out I can use my iPhone to reset that tangent mate
    I don’t know how to reset the tangent mate when using the desktop
    you may have to reset the tangent mate  and then immediately afterwards rotate the vertical shaft a little bit to get it to work
    @john_mcclary is the expert on mates. Maybe he knows a better solution
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,051 PRO
    When tanget mates start going funcky like that, try to replace them with relations instead.
    edited April 2022
    The rack and pinion relations weren't working the way I thought.
    I ended up making a surface that is tangent to the ball of the rod instead.
    It's a bit more controllable but it is still a tangent mate, so there is always a chance for it flipping inside out.
    Axle v.SS2 - Copy | Assembly 1 (onshape.com)
    @john_mcclary
    Had to call in the expert to get the job done right
    The good thing is — is I get a document to learn from — which I always like
    edited April 2022
    @john_mcclary
    I just opened up your document. What a great solution.
    A lot simpler than what I was thinking  I would have to go through to use a relation
    just a simple extruded circle
    Genius
    would be better to have a sketch with a single point to be tangent to the sketch rather than the rounded tip of the rod. Since a point on a curve is better than two curves
  • sarah_martinez903sarah_martinez903 Member Posts: 7
    Thanks for all the help. The modifications are helpful for students to see the motion they want. That will be a good workaround. I was hoping to get it in the orientation I had it, so it can show the direct movement of what will be happening in their actual device, but if there isn't that sort of solution, the workaround will let them see the motion at least, even if it doesn't directly match up to what they will be doing. @john_mcclary @steve_shubin
    edited April 2022
    @sarah_martinez903
    Hi Sarah
    You mentioned orientation
    These automatas are new to me. Sorry for the mess up on that orientation
    I found this on YouTube this morning.   Automata - YouTube
    I’m guessing you want the orientation to be as with the automata seen at the very start of this video — the one shown between 0 and  the 18 second mark.
    In the case of this one, the wheel attached to the vertical shaft is sitting ON TOP of the cam
    is this what you were looking for?
    Here is the updated document
    Yes, that's what I was trying to get
