Follower with rotating and translating movement
sarah_martinez903
Member Posts: 7 ✭
I am working on an automata project so that I can show students how to animate their projects. I have most things figured out, but I cannot seem to get a follower to both rotate and translate up and down with the follower. I know I need to do a gear relation, but that only relates the revolute of the follower and the axle of the main rod. I am looking to get the follower to follow along with the path of the cam and rotate, but anytime I try to do both things, my assembly breaks.
Here is the link, hopefully it works.
https://cad.onshape.com/documents/a7c1c1ab9dc6774e1d2994f6/w/ddd5d521065e30612d8be670/e/23cc3e415c13e911f4ad2eb0Thanks
SEE BELOW
https://cad.onshape.com/documents/8ddad83224c365f84606959b/w/92ebd1cffee14ecc2d8410e1/e/c8939d27d61b6e73b5f7a44a
in my previous post up above, that model was using a bit of trickery to get it to work. The vertical shaft was actually not rotating
But in this model, you can see that I added a little extra part that is FASTENED to the vertical shaft and that’s an indicator showing that that shaft is also moving in a rotational motion
I had to add an extra part to get it to do what it’s doing. The part is hidden
You have to manually crank that horizontal shaft to get everything to move
This is a finicky set up here. The assembly can go batty
but the GIF herein shows a fix
You just have to rotate the vertical shaft a little bit to reset it
As far as the tangent mate, I think it’s gonna just operate in the red. If it really falls out I can use my iPhone to reset that tangent mate
I don’t know how to reset the tangent mate when using the desktop
you may have to reset the tangent mate and then immediately afterwards rotate the vertical shaft a little bit to get it to work
@john_mcclary is the expert on mates. Maybe he knows a better solution
I ended up making a surface that is tangent to the ball of the rod instead.
It's a bit more controllable but it is still a tangent mate, so there is always a chance for it flipping inside out.
Axle v.SS2 - Copy | Assembly 1 (onshape.com)
Had to call in the expert to get the job done right
The good thing is — is I get a document to learn from — which I always like
A lot simpler than what I was thinking I would have to go through to use a relation
just a simple extruded circle
Genius
Hi Sarah
You mentioned orientation
These automatas are new to me. Sorry for the mess up on that orientation
I found this on YouTube this morning. Automata - YouTube
I’m guessing you want the orientation to be as with the automata seen at the very start of this video — the one shown between 0 and the 18 second mark.
In the case of this one, the wheel attached to the vertical shaft is sitting ON TOP of the cam
is this what you were looking for?
Here is the updated document
