Sketch Scale solution
Axel_Kollmenter
Member, pcbaevp Posts: 436 PRO
Hello,
I saw that back in 2020 the function to scale a sketch was implemented to onshape.
How does this work? I have a undefined sketch with a width of 240mm and want to scale it up to 320mm (all other lines should scale proportional)
( https://forum.onshape.com/discussion/8976/sketch-scale )
Best regards,
Axel Kollmenter
Axel Kollmenter
bryan_lagrange
Member, User Group Leader Posts: 985 ✭✭✭✭✭
You could use the transform command and scale it to the size you need. Just click on the triangle and enter the scale value.
If the sketch is has ONLY 1 DIMENSION, it will scale the entire sketch proportionally. You'll need to watch internal and external constraints that might prevent it from scaling.
This way you can make a sketch have the correct aspect ratio etc...then add a single dimension to scale the whole thing.
This also works when you place a DXF sketch into a sketch - works really well for imported wordmarks etc.
Axel Kollmenter
Twitter: @BryanLAGdesign
Axel Kollmenter
