Share only a Branch
bryan_lagrange
Member, User Group Leader Posts: 976 ✭✭✭✭✭
in General
Is it possible to create a branch of a part and share that branch with another Onshape user to possibly make changes to and would not make changes to the original design until approved by document owner.
Here is a scenario:
OEM company has a designed a bracket, and send the Onshape document branch that is set for the vendor for production and are open to make it more cost effective with a different manufacturing approach than what is designed.
OEM has designed the part to be machined.
Vendor receives branch of the Onshape document and can only work in this branch since this is the only permission given to them by the OEM.
Vendor can make it more cost effective by converting it to a sheet metal part and still keep design intent.
OEM can review what the vendor has done and choose to merge into the main design and move forward with the vendors design change.
Giving permission to the vendor to just a branch can allow the vendor to make changes to the part and at the same time does not affect the original design of the OEM. Is this something Onshape can do?
3
Twitter: @onshapetricks & @babart1977
Twitter: @BryanLAGdesign
