Split by UV curve?
EvanReeseEvanReese Member, Mentor Posts: 3,002 PRO
Using opCreateCurvesOnFace() I can generate UV curves for a given face. Is there a way to split that face with the curve without making surface geometry to do it?
  • MichaelPascoeMichaelPascoe Member Posts: 2,917 PRO
    Not atm. @Jacob_Corder?
    RENDERCAD
    RENDERCAD
  • EvanReeseEvanReese Member, Mentor Posts: 3,002 PRO
    @MichaelPascoe
    I looked at how you approached it on Thickness Analysis, and I'm essentially trying to avoid doing that, haha. It's a good solution given the tools we have but I'm betting it wasn't your Plan A either.
  • mahirmahir Member, Developers Posts: 1,324 ✭✭✭✭✭
    @Evan_Reese For (mostly) better or worse, OS is not Catia  :D
    edited August 2022
    Yeah, that was not the route I wanted to take..
    RENDERCAD
  • S1monS1mon Member Posts: 4,346 PRO
    @Evan_Reese
    I don't think there's anything available now, but there may been something soon, based on some discussions. Theoretically, splitting a surface by U or V is relatively simple mathematically, and should leave you with two surfaces which are identical to the original.
    This isn't 100% what you're asking for, but I made an IR a while back for move boundary by U or V.
    Definitely clever given current constraints.
    S1mon said:
    @Evan_Reese
    Good to know from a fundamental level it's not prohibitive. I know the functionality is a bit niche, but I can think of a few custom features it would make possible.
    Credit to @Jacob_Corder for that one.
    RENDERCAD
  • Jacob_CorderJacob_Corder Member Posts: 141 PRO
    I found that opSweep with lockFaces was the fastest method for generating a small surface to split the faces with.  Solidworks had splitFaceOnParam which would essentially be what you are asking for.  I have a strong feeling very soon it will be available to us. It will likely be a split face with curve hopefully, then opCreateCurvesOnFace can indirectly split a face with the use of the curve itself.
    Another way to do it would be to use opCreateBSplineSurface and supply the boundaryBSplineCurves. this generates a new face and a thicken would likely need to be created to split the face you want. this also is likely not going to be a fast approach but would allow you to create a inner loop split on a face.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 6,078 image
    edited October 2022
    There is now, in the Split Face feature.
Howdy, Stranger!
