How to make sketch cursor cross + larger?
george_dvorak795
Member Posts: 4 ✭
I am on a 50 inch monitor at 3840 x 2160 and when sketching the black cross cursor is about 2 mm high on the screen.
How can the size be increased? Can cursor color be changed?
Thank for any help.
Hi - cursor size is controlled in your operating system settingsSenior Director, Technical Services, EMEA1
Hi Neil,
Thanks for your reply. But the black cross + does not change when I change my cursor size. It is always small.
I have attached screenshots of Onshape with a cursor size of 16 and a size of 72.
Images numbered 1 2 3 4 are a cursor size 16. Note the small mouse pointers and small black cross +.
Images 5 6 7 8 9 are cursor size 72. Note the cursors are all large but the black cross + remains the same small size.
Thank you,
George
Please open a support ticket about this and somebody will take a look. Any reason why you are running the 5K screen at 5K? I see you have zoomed the browser, but in the meantime it may help to reduce the screen resolution.Senior Director, Technical Services, EMEA0
Is there any update to this question? There must be a way to change the setting in OnShape? changing the PC settings has no effect on the sketch editing cross hairs.
