Many instances of same entity in sketch, linked/synced/etc, or copy+paste with equal constraints?
Basically the same question as this old one from 2015 https://forum.onshape.com/discussion/279/copy-sketch-elements-within-sketch
I have a sketch where I need to place around 50 arrows, but I don't know the exact dimensions of them yet (and it may require some tweaking and multiple passes to get the fit I need).   They'll all be in different positions and have different orientations.  I want to be able to place them all, and then edit the original and have them all update, similar to how a linear/circular pattern does.  The only way I can find to accomplish this at all is to have every component of every arrow have an 'equal' constraint tied to the original, but that'd require me setting up 8 constraints x 50 arrows one by one.  I had assumed just making one copy with these equal constraints, and then copy-pasting that copy would work, but the copy-paste seems to lose any equal constraints that reference another entity, so that doesn't work
