Watermarking of 3D Model
imagineered
Member Posts: 57 ✭✭
in General
Not that I expect this to be available within Onshape, but has anyone had experience with watermarking a 3D model?
For security of models, I would be interested in the ability to provide a dumb solid with a watermark that cannot be removed (or so difficult to remove it wouldn't be viable )
Any experience or ideas??
3dcad
Member, OS Professional, Mentor Posts: 2,476 PRO
Note that even if you share 'View-only' the viewer is able to make a copy of your document.imagineered said:... Sharing through Onshape may be the best solution
This thread has more discussion on view-only:
https://forum.onshape.com/discussion/1851/is-is-possible-to-share-a-design-as-view-only
//rami5
The problem I have seen is that some clients are wanting Solid Models to inspect & this can cause commercial problems.
ie taking the info elsewhere to have manufactured and or collecting info without payment.
2D drawings are easy. 3D is a prob. Sharing through Onshape may be the best solution
Basically want theft prevented - or at least models to be unusable until paid for
