Hide transition lines in a part or assembly
ricardo_raimondo
Member Posts: 33 ✭
in Drawings
I designed the part below and used several tools to make the shape. As a result, what I called transition lines (maybe the wrong name) appear wherever parts join each other or fillets are added. As a view for a screenshot that looks really ugly. The question is: Is there any way to hide those lines in the online version of onshape?
In the drop-down menu of the small cube menu in the upper right corner, select the shaded with hidden edges. I think that should take care of your problems.
