Any way to increase the size of dimension entry?
james_howard360james_howard360 Member Posts: 28 PRO
Is there a way to increase the size of the 'Value' field or show it as multi-line? I'm building expressions in Notepad++ and pasting them in, but if OnShape decides there is an error, scrolling back and forth repeatedly to find an error in a field that's limited to 20 characters is extra tedious.
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,119 PRO
    Look into featurescript. It's easier than trying to use 1 liners.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,549 PRO
    edited January 2023
    Still would be useful to be able to pop out the expression field though...
    Even a simple expression with a couple of variable requires scrolling back and forth!  Even just allowing us to temporarily resize the whole input dialogue (so we could make it the width of our screen) would go a long way!
    There's an improvement request for it: https://forum.onshape.com/discussion/comment/48300#Comment_48300
  • edward_petrilloedward_petrillo Member Posts: 101 EDU
    I ran into the same problem, then I noticed that if I created a variable in a Variable Studio, I could expand the width of the "Value" column to a comfortable size..  You're forced to use the separate tab instead of entering your expression in a sketch, but it gets the job done.  Looks like the improvement request hasn't attracted a lot of attention.
  • EvanReeseEvanReese Member, Mentor Posts: 2,825 PRO
    I wish!...like, often.
  • johnathan_gander778johnathan_gander778 Member Posts: 2
    Right click page or hit F12 to inspect. Paste the following in the console and hit enter.
    let width = 30; // % browser width
    let style = document.createElement('style');
    document.head.appendChild(style);
    style.innerHTML = `.dimension-edit-container .ns-feature-parameter .bti-numeric-text, .dimension-edit-container os-quantity-parameter input {width: ${width}vw!important;} .dimension-edit {max-width: ${width}vw!important;}`;
    Change '30' above to desired width as a percent of the browser's. This will stay active until you refresh the page.
    Also, the UI windows can be dragged to widen now, which wasn't the case in 2023.
