Trim previous sketch entities with FS?
- opPattern() to copy the input sketch curve in place
- opSplitPart() to cut it into 2 wire bodies since opSplitEdges() does split the edge, but keeps it as 1 wire body somehow.
- opDeleteBodies() what I don't want to keep
Senior Director, Technical Services, EMEA0
@Evan_Reese
Now I know nothing of featurescript shorthand such as opPattern()
But maybe this approach might help
So with regards to getting a curve to where it can enter the feature world, where the feature is dependent on direction, I wonder if this would work
My idea is to combine the code of the following features - into your feature. I'm assuming you can look at and copy the code behind various custom featurescripts.
For starters, you mentioned manually assigning a direction
So to do this, if you could incorporate the code of MultiMateConnector to act as an IMPLICIT MATE inside your feature
Next, you would need to make a CUSTOM EXTRUDE FEATURE, made up of the code of the following 3 features. Extrude Vertex, Curve Pattern, Loft - and these combined, would give the result of an extrude surface. See Part Studio — BETTER WAY
So once you have a surface object, you could use all kinds of other features on it.
Note - I’m pretty sure the curve that am starting with, is not planar
I hope this made at least a tiny bit of sense LOL
See the doc below
I'm wondering about maybe feature patterning the input sketch and working with that, since I assume it would still have a plane, but that option is about an order of magnitude more complex than I think it needs to be.NeilCooke said:0 -
@steve_shubin
Thanks for this. It's not that I can't personally get the curve to extrude—I can just pick a "real" sketch edge first, then my funny one, since extrude direction is determined by the first entity picked (as one example). My issue is that I want other people to be able to without having to think of it any differently than a normal sketch.
As an aside, I did notice that even the new "extrude direction" option in extrude doesn't overcome this issue, but I feel like it could be updated to make that work. That's another topic though.0
