Extruding from a dxf file
in Drawings
Whats the best way to get an outline or vectored sketch into Onshape from illustrator?
i want to be able to import the outlines as a sketch and then extrude
I see theres something happening with dxf importing but dont see an actual result
Once the dxf is imported to the Onshape doc, if in the right format you should be able to add from a sketch.
Twitter: @onshapetricks & @babart1977
