How to create differently sized instances from a generic part?
Newbie question.
Tried to make a generic part with variables for the main dimensions.
Then I realised that when I change the variables in the part definition, all instances, even older references change.
Thinking some more, that is of course the way it should work.
https://cad.onshape.com/documents/c90604e98a644367954e2dcb/w/e803d1da78c441d69fe8f9f6/e/4c64e9abf026404d83bc2db3
So, my question is, how do I create a generic base part that can have differently dimensioned instances?
  • florian
    florian Member, OS Professional Posts: 110 ✭✭✭
    Hi Lars,
    have a look at my similar loosely related question on configurations for some hints. However, there isn't a robust solution yet.
    Cheers, Flo
  • lars_andersson
    lars_andersson Member Posts: 20 ✭
    "Derive that part" would that be done by Duplicate in the Part Studio tab? Then I guess ordinary dimensioning would do as well as variables?
    I played with exporting the part as Parasolid and reimporting the part in a new Part Studio, then changing the variables in my mother part and then repeat export/import.
    If that process could be automated ...
  • andrew_troup
    edited November 2015
    @lars_andersson
    I was thinking more in terms of a live link than a dead one.
    Duplicate results in a dead link: changes to the parent are not reflected in the child.
    "Derived" creates an associative link, as described here :
    https://cad.onshape.com/help/#derived.htm?TocPath=Modeling%20in%20Onshape|Part%20Studio|Feature%20Tools|_____25
  • christophe_ribal
    christophe_ribal Member Posts: 3 ✭
    Hi !
    I'm wondering if there has been any improvements on this, such as a function: "Import As" where the set of modifed variables could be set independently from their state on the mother part, even if larger design changes could happen there and be reflected to the child.
    Is this on the to-do-list for Onshape ?
