Grammarly extension within onshape
Alexandre_WamainAlexandre_Wamain Member, csevp Posts: 16 PRO
My question is related to using the Grammarly extension within onshape. Particularly within drawings double checking that I'm not misspelling anything. I can't figure out how to make it work, is it possible?
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,640 PRO
    Having spell check work in drawing notes would be a good starting point...
    I'm guessing that whatever Onshape is doing that prevents spellcheck from working is also going to prevent Grammarly from working.
    Does it work in other areas within Onshape where spellcheck does work? For example when editing feature names?
  • Alexandre_WamainAlexandre_Wamain Member, csevp Posts: 16 PRO
    Just gave it a try and doesn't seem to work when I attempt to rename a feature with a misspelling. That being said the built-in spell checker did underline the feature name as red.
  • Nath_McCNath_McC Member Posts: 136 PRO
    edited May 2023
    I vote for Grammarly intergration
    It works on comments, properties, and release candidates, basically anywhere where there is a multiline text box (but not drawings).
    So basically everywhere except where it's most needed!
    Do you guys have a plan for addressing this?
