Preparation for Single Sign-On for the Forums (UPDATED)
lougallo
Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015
Very soon we will be getting Single Sign-on (SSO) in place for our forums. This should make the link between Onshape and the community simple. However, some of you have used a different email address for the forums than you did for Onshape and this might cause some issues in this SSO transition.
In anticipation of this change, please check to make sure that your profile on the forum has the same email address associated with it as your Onshape sign-in. If it does not match, follow the steps below to correct it:
We hope this makes the transition over to the forum streamlined and avoids having to manage two accounts. Thank you for the time. ~Lou
- Click on the gear (
) -> Edit Profile - Under Email, type in the email you use to login to Onshape
- Click Save.
Single Sign-On (SSO) is operational! There are a few things still to do for those of you that might come to the forums directly and are not currently signed into Onshape. So here are the details for the various scenarios for now:
