"Wrap" sketch around non cylindrical object
joshua_sams
Member Posts: 21 PRO
so I have this little button cap. it needs a cut added to it that needs to be the same depth over the entire surface (when measured from the surface face) which is very similar to how wrap works.
I can't use wrap because that's only for cylinders. any other ideas?
https://cad.onshape.com/documents/c6c63936b2d0b12be5a91753/w/ccf93ffb06b514a7bf9e7eb5/e/536fc5db139bc60ae155d2a9?renderMode=0&uiState=65c943b42f717b21ad5ae07f
I will admit I don't quite understand what the split operation is doing but i was able to copy it and get exactly what i wanted!
thank you!
