Change to Part causes Revolutes to go RED and not to work
IMK
IMK Member Posts: 13 ✭
edited July 2016 in Community Support
Hello,
I have design a simply crank arrangement as can been seen in image  Revolutes-OK.jpg
This functions as expected inasmuch as you turn the green crank knob and the yellow sliders moves up and down.
Problem is when i make a small change to the slider (Yellow) by adding a Fillet to the bearing post the Revolutes and the Slider item go RED and the crank not longer works. So is there some kind of model rebuild function like in Alibre F% i have mist or do it need to re do all the assemble Revolutes and Slider Mates.
Many thanks and a happy holiday IMK
  • 3dcad
    Can you share your model in public and post a link here?
    I think you will lose the reference for mating with that fillet. You can see the error message by hovering red mates.
    That could be fixed with creating a mate connector in part studio (before fillet) or mating again using different mate connector.
    //rami
  • IMK
    edited December 2015
    3D Cad,
    Many thanks for reply, popup message is.
    mate overdefines the assembly
    and have shared the document here:
    https://cad.onshape.com/documents/0a4f675656724b05a8d12956/w/0d8ee9f3fe524dd5ba4d3625/e/4c025de451b84b6285ac0d4e
  • _Ðave_
    _Ðave_ Member, Developers Posts: 712 ✭✭✭✭
    See Gif below. If you use the bottom edges for the revolve mate then you can change the top fillet at will without affecting the assembly function. HTH
    4.gif 3.7M
  • IMK
    Hello,
    Many thanks for the help everyone, i guess i have a lot to learn about the subtleties of the mates and how best to use them.
    But was surprised to see how one failing mates caused the rest to fail.
    Anyway fixed now thanks again and have a good holiday.
    BTW how did you make the gif please?
  • _Ðave_
    i use Licecap, it's very simple and easy.
  • 3dcad
    Thanks @_Dave_ for jumping in after my bedtime..
    This forum is amazing, the group of people that are willing to help has grown all the time. The response time is magnificent with helpful people around the world with different time zones (and different usage hours).
    Not to even mention those amazing gifs people produce just for pushing another user on right track.
    All you people who take your precious time to help - be proud of yourself!
    I'm glad things wen't like I thought they would in April 2015:
    https://forum.onshape.com/discussion/comment/3520/#Comment_3520
    //rami
