How do I extract the intersection curve of a part and a surface?
ron_moreland
Member Posts: 90 ✭✭
NeilCooke
Moderator, Onshape Employees Posts: 5,926
Hi Ron - if the surface is closed or extends past the boundaries of the part then you can use Split Face, or if the surface is planar you can use Intersect in sketch. Another method would be to thicken the surface then Boolean subtract one part from the other to get the intersection. Your example shown above is not possible to do in one operation at present. Hope this helps.Senior Director, Technical Services, EMEA5
