How to add revolves into an extruded cylinder
henry_feldman
henry_feldman Member Posts: 136 EDU
So I have this cylinder (just a simple extrude with a chamfer on each end. This is a pin going onto a handle, and I want small bulges to keep the pin from falling out of the handle. I cannot figure out how to add a revolved shape (yes I realize I could recreate the entire shape as a revolve, and if that's the only way, then fine) of the little bumps (i.e. a toroid) to each end (essentially where the boxes/arrows are)?
  • matthew_menard
    matthew_menard Member Posts: 96 ✭✭✭
    Should be very easy.  Make a sketch on a plane that is along the middle of the extrude.  Add two rectangles and dimension them per your specs.  I did have to use some construction geometry to make them coincident with the outer diameter, see my example.  Finally just revolve around the center of your part.  Below is just one way of doing this.  You could also make one rectangle and mirror the resulting faces to the other side (I think, didn't try).  Hope this helps
    https://cad.onshape.com/documents/4d3a3befc86f475c86e135ad/w/ea2bd8a23ebc4bdcbf2079cf/e/e6db51c1526b49d3948583c7
