Drawing Involute Spline
thomas_hotchkinthomas_hotchkin Member Posts: 8 PRO
Hey all,
I'm trying to model a spline (mechanical connection) which can be cut using a 6mm end mill, with an involute profile on the teeth. To do this I've drawn an unravelling circle in the sketch to get the involute profile, and joining it with a spline (curve), however I'm struggling to get a fully defined sketch because of the tangent handles on the spline.
Can anyone recommend a way to fully define the sketch or a better way to achieve this geometry?
You can find a sample of the model here.
Thanks!
